ClearPass Intune extension
This thread has been viewed 84 times
  • 1.  ClearPass Intune extension
    Posted Nov 09, 2023 07:25 AM
    Hi guys,
    I'm currently migrating ClearPass from 6.9 to 6.11 with ClearPass Intune extension.
    In ClearPass 6.11 have the exact same service for the customers Wi-Fi but the ClearPass extension cannot lookup the mac-address. The extension is searching for the IntuneID which is not configured.
    [2023-11-09T12:46:26.445] [INFO] Intune - [id] Request for information received from ::ffff:172.17.0.1.
    [2023-11-09T12:46:26.445] [DEBUG] Intune - [id] Performing device lookup.
    [2023-11-09T12:46:26.447] [INFO] Intune - [id] Device not found.
    [2023-11-09T12:40:07.273] [DEBUG] Intune - ce32b8ad-a293-4a3e-a1c1-f079e91ab08a Processing the MAC Address 88c08b093017 for device da0fe22a-dadb-4974-aede-9535dfee773a... [2023-11-09T12:40:07.273] [INFO] Intune - ce32b8ad-a293-4a3e-a1c1-f079e91ab08a No updates to 45398 (88c08b093017) in ClearPass - skipping. [2023-11-09T12:40:07.273] [DEBUG] Intune - ce32b8ad-a293-4a3e-a1c1-f079e91ab08a Processing device b4272cd9-ba3a-4ecd-a5cf-d7fce00399d5.
    My older Intune extension v4.0.0 is quering the mac-address the right way
    [2023-11-08T13:20:51.516] [DEBUG] intune - Querying Intune at https://fef.msub05.manage.microsoft.com/StatelessNACService/devices
    [2023-11-08T13:20:55.366] [DEBUG] intune - Request received. /?macAddress=8cc681d10f2e
    I don't have access to Intune myself but the new enterprise app is configured the same as the older ones.
    What could be the issue? I cannot migrate the Wi-Fi users to the new cluster.
    In the meanwhile I cannot test the wired part of my project as well.
    Is there a bug or am I doing something completely wrong?
    Best regards,
    Erik
  • 2.  RE: ClearPass Intune extension
    Posted Nov 09, 2023 08:18 AM
    Erik,
    That is expected. The newer Intune Extensions use different APIs (GraphAPI), instead of older (deprecated) APIs. Part of that is that lookup is done through the Intune DeviceID, no longer to the MAC address, except that you can use the sync option to sync Intune data to the Endpoint Database and lookup by (wireless!) MAC there.
    I did a presentation at a recent event in Belgium, where the slides are posted here. It also explains why using the MAC address to lookup/link security data is a bad idea in many cases.
  • 3.  RE: ClearPass Intune extension
    Posted Nov 09, 2023 08:32 AM
    Hi Herman,
    thanks for clarification.
    But how can I migrate for the time being from the "old" cluster to the new one?
    Is there a way to install a new and an older Intune extension?
    Erik
  • 4.  RE: ClearPass Intune extension
    Posted Nov 09, 2023 08:47 AM
    Probably, yes... you can install multiple Intune extensions in parallel. Just be a bit careful to prevent that both extensions synchronize to the endpoint database at the same time. For HTTP Authorization, it shouldn't be an issue.
  • 5.  RE: ClearPass Intune extension
    Posted Nov 09, 2023 08:53 AM
    Is there a guide available how to install it?
    My search results gave me only the latest version in the extension.
    Erik
  • 6.  RE: ClearPass Intune extension
    Posted Nov 10, 2023 08:42 AM
    In that case you may need to go through TAC. If you have the extension ID from your current installation, you may be able to install based on the ID, but not sure if older versions are still posted.
  • 7.  RE: ClearPass Intune extension
    Posted Nov 13, 2023 04:28 AM
    Thank you Herman, I created an TAC case.
    Case closed
  • 8.  RE: ClearPass Intune extension
    Posted Nov 13, 2023 07:22 AM
    Even if you installed the old extension, there will likely be issues because Microsoft changed the Graph API behaviour that the extension uses.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
  • 9.  RE: ClearPass Intune extension
    Posted Nov 14, 2023 12:06 AM
    the current version of clearpass intune extension is 6.1.7
  • 10.  RE: ClearPass Intune extension
    Posted Mar 05, 2025 11:19 AM
    Is there a setup guide on Intune extension for 6.3.5.
    We did a upgrade from 6.10 to 6.11 and the intune extension didn't import. So I installed the latest 6.3.5 and I get the error:
    [2025-03-05T11:03:02.401] [INFO] Intune - [20-1e-88-fb-f5-9f] Request for information received from ::ffff:172.17.0.1.
    [2025-03-05T11:03:02.402] [INFO] Intune - [20-1e-88-fb-f5-9f] Device not found.
    I see from Herman's slides - he has "filters $(Certificate:Subjuect-CN)"
    Just wondering if theres a guide that goes over this more in depth. Thanks!!
  • 11.  RE: ClearPass Intune extension
    Posted Mar 05, 2025 11:27 AM
    This is the latest version of the TechDocs
    Looks like you're using the old way of intergration. Based on MAC address lookup. Latest versions will do a lookup using attributes information fetched from the certificate. This is documented in the TechDoc.
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 12.  RE: ClearPass Intune extension
    Posted Mar 06, 2025 02:16 AM
    One thing I have noticed is that the Intune sync to Endpoint database is useless when you have Android phones. Intune does not store Android phone mac addresses and the Intune extension cannot sync Android phones to Endpoint database. So we have to use the HTTP query method for authentication and the Endpoint database is useless for authentication.
    Istvan
  • 13.  RE: ClearPass Intune extension
    Posted Mar 07, 2025 01:17 AM
    Willem will there be an updated version of the doc for 6.3.5?
  • 14.  RE: ClearPass Intune extension
    Posted Mar 07, 2025 05:20 AM
    The docs will be updated when new features are available. In this case 6.3.x updates are included in the docs.
    Changes in the 3rd numbers are always bug fixes or minor security adjustments/updates.
    Willem Bargeman
    ACEX #125
