  • 1.  ClearPass Intune Extension - two Intune instances
    Posted Feb 27, 2025 05:42 AM
    Hello all,
    We have a customer who has merged with another business. They already use the Intune integration on ClearPass. Is it possible on the same ClearPass to authorise users on another Intune instance. They will be using the same, existing SSID for both companies devices.
    Would we need to install another Intune extension or can the existing extension be configured two query two Intunes?
    Jason
  • 2.  RE: ClearPass Intune Extension - two Intune instances
    Posted Feb 27, 2025 06:47 AM
    You can run an additional Intune extension. Just search for Intune in the extension store and click install.
    Keep in mind that the second Intune extension will have another IP address. For example, you can have two services to authenticate the device. 1 for Company A and the other one for Company B. Just make sure that match the right service (for example based on the username field)
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 3.  RE: ClearPass Intune Extension - two Intune instances
    Posted Feb 27, 2025 07:38 AM
    Hi Willem,
    Thanks for the confirmation.
    Jason
    Jason
