  • 1.  Clearpass Issue
    Posted Dec 03, 2023 10:27 AM
    Howdy - I had a very strange problem that happened the other day. In Services, I made a copy of our production wifi and set to #28 in the priority list - I made copies of the role map and enforcement so I can have this new 802.1x services all by itself. I'm also using SCEPman with Jamf -- it was working correctly all week and then all of sudden the access tracker stopped showing - couldnt see any connections or rejects at all. So I disabled my service that I created and boyahh access tracker starts showing events again ....has anyone had this happen?
  • 2.  RE: Clearpass Issue
    Posted Dec 06, 2023 08:43 AM
    Did you enable an Azure AD (Entra ID) AuthZ as one of your Authentication Sources?
    If so, move it as an Authorization Source. This is a known issue that authentication stops when Azure AD is added as Authentication Source, and I think it has been fixed in the later 6.11.x releases already.
  • 3.  RE: Clearpass Issue
    Posted Dec 06, 2023 03:13 PM
    Thats exactly what happened. I was using Local AD as the Auth and then changed it to Azure AD -- were running 6.11.3.253363
    Brian Mitchell (he/him) | Director Of IT
    Dwight School New York
    18 West 89th Street, New York, NY 10024
    212-724-6360 x456 | dwight.edu
