Clearpass - NMAP for static IP from framed-IP-address
  • 1.  Clearpass - NMAP for static IP from framed-IP-address
    Posted Mar 19, 2025 06:18 AM
    Does anyone have experience with profiling when there are static IP addresses or only a local DHCP?
    I know that ClearPass can search for an IP address using an SNMP query to switches and routers, but in this case, it's not possible because Meraki allows SNMP only from local IP subnet or through cloud management.
    ClearPass receives the endpoint's IP address in the Radius Accounting Framed-IP-Address, but it doesn't use it for NMAP scanning.
    Does anyone know how to integrate this together?
    Clearpass version 6.12.3
    Regards
    Piotr Filip
    ACEX#41/ACCX/ACDX/ACMX/ACX-CAM/ACX-NS/CWNA/CWSP
  • 2.  RE: Clearpass - NMAP for static IP from framed-IP-address
    Posted Mar 24, 2025 12:17 PM
    Hi !
    I am also interested by this use-case.
    UP
    Mathieu
    CyberSec & Network Engineer - ACCX #1532 - ACX-NS - APC ClearPass - ACMP
