  • 1.  Clearpass Onboard with MFA SMS, Phone from AD
    Posted Jan 19, 2017 10:43 AM
    Hi Team
    The authentication source of onboard is the active directory. the mobile number is stored in the active directory as well, I can see it in the clearpass access tracker. after that I will use MFA with SMS.
    How can I use the phone number from the active directory for the MFA SMS process?
    Thanks for your help, regards
    Manuel
  • 2.  RE: Clearpass Onboard with MFA SMS, Phone from AD
    Posted Jan 20, 2017 06:51 AM
    Good question! I can't easily see how to do this but would also like to know if possible.
  • 3.  RE: Clearpass Onboard with MFA SMS, Phone from AD
    Posted Jan 20, 2017 06:54 AM
    In the meantime I found the following hint:
    "For LDAP/AD the Pre-Authentication service must be updated to include the numbers in the reply."
    Sound like we have to include the phone number in the radius reply attributes. But which one?
    rg Manuel
  • 4.  RE: Clearpass Onboard with MFA SMS, Phone from AD
    Posted Feb 01, 2017 05:36 AM
    Hi all
    In the meantime I got the glue. We need a Enforcement Policy like (find atteched):
    ClearPass:visitor_phone=%{Authorization:SOFTEC AD:mobile}
    This only works with App-Auth (not radius based). Then we can use the attribute "visitor_phone" in the onboard or guest workflow.
    Regards
    Manuel
