Clearpass OnConnect- Multi-Domain Auth
  • 1.  Clearpass OnConnect- Multi-Domain Auth
    Posted Sep 30, 2018 03:07 AM
    Can anyone please let me know whether SNMP On connect will work with a laptop and phone from a single swithc port like 802.1X.?
    Faiz
  • 2.  RE: Clearpass OnConnect- Multi-Domain Auth
    Posted Oct 01, 2018 03:24 AM
    I think for such a scenario, using MAC authentication is a better solution. If you follow the Wired Authentication Solution Guide, it should help you get started with that. In general, you should use OnConnect only in situations where you really can't use MAC authentication.
