  • 1.  clearpass onguard login credentials keeps popping up
    Posted Dec 19, 2022 09:42 AM
    Hi
    clearpass onguard login credentials keeps popping up continuously & when I use my credentials it shows a massage (Authentication Failed )
    but no other issue except that.
    Knowing that this happened on the next day when I renewed the HTTPS server certificate and it is a CA cert
    in access tracker this is what shows me
    TACACS
    username [Policy Manager Admin Network Login Service] REJECT
    clearpass onguard mode: check health- no authentication
    how to fix it,please?
  • 2.  RE: clearpass onguard login credentials keeps popping up
    Posted Dec 20, 2022 03:25 AM
    Kind of figured out the problem, I've two devices one publisher & subscriber but the subscriber is out of sync for more that two days   But is pingable
    the FIPS is enabled
    And somehow can not drop the subscriber from both and the VIP
    the issue is that onGuard is connected to the subscriber after the renewal somehow
    how can I fix subscriber & why or how to make OnGuard connect back to the master knowing that I turned off the all the services on the subscriber but OnGuard keeps waiting until the subscriber is back it looks like the OnGuard doesn't see the publisher
    if I turns off FIPS what will happen
    any help pls
  • 3.  RE: clearpass onguard login credentials keeps popping up
    Posted Dec 20, 2022 03:34 AM
    Hi
    Normally you should only enable FIPS if you have a requirement to be FIPS compliant.
    Do you have virtual IP addresses (VIP) configured? If so you need to remove the VIP configuration from the Subscriber before you drop the subscriber from the cluster and then make it a subscriber again.
    As the node have been out of sync for more than 24 hours it will not be possible to come back in a functioning cluster without dropping the node.
    If you can't drop the node, open a support ticket with Aruba TAC to work on the issue.
    Best Regards
    Jonas Hammarbäck
    ACCX #1335, ACMP, ACDP, ACNSP, ACEP, ACSA
    Aranya AB
  • 4.  RE: clearpass onguard login credentials keeps popping up
    Posted Dec 20, 2022 03:45 AM
