ClearPass OnGuard MacOS 15 Sequoia
This thread has been viewed 60 times
  • 1.  ClearPass OnGuard MacOS 15 Sequoia
    Posted 25 days ago
    Anybody experience ClearPass OnGuard not support for MacOS 15 Sequoia ?
  • 2.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 24 days ago
    Won't be officially supported until the next patch release for ClearPass.  ClearPass OnGuard doesn't support beta OS releases, and support for the released OS is usually added with the next patch of ClearPass.
    Carson Hulcher, ACEX#110
  • 3.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 24 days ago
    Hi chulcher, there is workaround to run onguard agent on macos 15 ?
  • 4.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 24 days ago
    Wait until support is released.
  • 5.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 23 days ago
    Hello Chulcher,
    Is there any forecast for updating ClearPass? since the launch of MacOs Sequoia 15 has already been made official.
  • 6.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 23 days ago
    This is being worked on as quickly as possible.
  • 7.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 19 days ago
    Hi, Chulcher
    Any update about this case or there is workaround to run onguard agent on macos 15. In my company users are applying the update.
  • 8.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 18 days ago
    This is why I always tell customers not to use OnGuard/OnBoard/BYOD. Some OS updates turn into support nightmares and you are 100% at the mercy of the vendor waiting for a patch.
    What is the use-case for OnGuard? Why aren’t these endpoints managed by an MDM where the organization can control updates? What is the use-case for allowing unknown/unmanaged endpoints onto the trusted network?
  • 9.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 18 days ago
    Still being worked on.
    Why are you allowing your users to update their devices when not all managed software is compatible?
  • 10.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 16 days ago
    The hotfix for support of MacOS 15 in OnGuard has been published for ClearPass 6.11.9, should be downloadable through software update or you can grab from the support portal.  The 6.12 version isn't currently showing for me but should be available soon.
  • 11.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 15 days ago
    I have tested this with macOS 15 and it works! Thanks! The version of OnGuard is 6.11.9.259763
  • 12.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 24 days ago
    Are these MacOS devices managed by an MDM?  If not, why not?
  • 13.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 18 days ago
    OnGuard 6.11.9 is not working on macOS 15 or macOS 15.1 beta 5. I opened an Aruba case during the macOS 15 beta time and was told Aruba does not support beta OS. MacOS 15 Sequoia is final, has been released to the public and it still does not work.
  • 14.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 18 days ago
    Yes.  My first response in this thread covered this.  Being worked on as fast as possible.
  • 15.  RE: ClearPass OnGuard MacOS 15 Sequoia
    Posted 18 days ago
    Thanks for the update, it is appreciated!
    best,
    steven
