  • 1.  Clearpass OnGuard Notifications
    Posted Nov 06, 2024 10:49 AM
    Hi there.  I'm currently about to roll out OnGuard agent to a test group in my building before hitting several thousand users with it.  When setting the rules I saw that I can include a grace period for users who breach a rule.  We decided to give users a couple of hours grace before the agent kicks them into the quarantine VLANs I've set up.  In testing I found that there appears to be no notification at all that you are about to be quarantined.  I was hoping for a pop-up warning the user that they had 2 hours before they would be quarantined, much like when rolling out updates.  The user would have no clue they were about to get cut off.  Is there a way to get a pop-up of some kind for a warning when using grace period?  Otherwise it's almost useless..
  • 2.  RE: Clearpass OnGuard Notifications
    Posted Nov 07, 2024 10:51 AM
    I haven't seen that option. What I understood the feature is designed for, is to allow for example endpoint security policies to be updated in the background, instead of dropping in a restricted role the moment something is out of date. If others reading this know something, please let it know. If you have contact with a local Aruba Sales team, or your Aruba partner, they may check this with the product managers.
  • 3.  RE: Clearpass OnGuard Notifications
    Posted Mar 18, 2025 03:11 PM
    Hi ,
    You got any resolution for this issue?
    Prasad Bhosale
  • 4.  RE: Clearpass OnGuard Notifications
    Posted Mar 19, 2025 12:49 PM
    I have also seen this behaviour, there is no notification as it is basically the same as Healthy state until grace time runs out.  I think this should be requested in the Aruba Innovation zone as it makes sense to give a warning at the start of the grace time so user can correct the issue...
