After I forgot it, it worked as expected. It was definitely a window side.
Original Message:
Sent: Mar 25, 2024 06:41 AM
Subject: ClearPass Policy Manager 6.12.1 with TEAP Method
Everything looks fine and it's strange that there is a problem.
Can you send the log from Access Tracker? You should have 3 logs:
1. Computer authentication
2. Computer authentication and user authentication error
3. Correct authentication of the computer and the device after manual connection.
Take screenshots and export logs for these 3 cases.
Regards
Piotr Filip
ACEX#41/ACCX/ACDX/ACMX/CWNA/CWSP
Original Message:
Sent: Mar 22, 2024 10:40 AM
I am only using one cert of the user and one cert for the machine.
When I disconnect and reconnect, it works as expected. I don't have to choose between cert.
Original Message:
Sent: Mar 22, 2024 09:35 AM
Everything looks good.
I see that you use the certificate for both authentication. Do you have many certificate for user ? When you manually reconnect, do you have a choice of certificate ?
If yes, you need to configure EAP-TLS which is inside TEAP.
Regards
Piotr Filip
Piotr Filip
Original Message:
Sent: Mar 21, 2024 10:40 AM
Yes, here it is.
Original Message:
Sent: Mar 21, 2024 10:35 AM
In supplicant you have button settings on right from configuration TEAP. Can you do screenshot from this ?
Regards
Piotr Filip
Original Message:
Sent: Mar 21, 2024 09:56 AM
Yes, we manage all of our windows computers in Azure.
I am not sure what you meant by which method do I use form computer and user? Do you mind explaining further.
Oumar
Original Message:
Sent: Mar 21, 2024 09:45 AM
What method do you use for computer and user ?
Do you have managed computer by Azure AD ? It change GINA login to SAML.
Regards
Piotr Filip
Piotr Filip
Original Message:
Sent: Mar 21, 2024 09:34 AM
Forgot to mention. At the login screen, when you join the network, the machine auth works perfectly. But as soon as the user login you have to disconnect and reconnect the wifi for the user Auth to appear.
It works fine the opposite way when the user sign-out, the machine takes place which is the expected behavior. I am just trying to get around from disconnecting and reconnecting to the wifi every time as we have machine that we loaned to users.
Original Message:
Sent: Mar 21, 2024 09:27 AM
Yes, I have the option "user or computer authentication" in advanced settings of 802.1x windows supplicant chosen.
I am using Intune plug-in for Authentication since I can't use Azure AD.
I can also share my config from the set-up I did in the clearnpass. I have followed the documentation that I have found online.
Original Message:
Sent: Mar 21, 2024 02:22 AM
Hi
Do you have configured option "user or computer authentication" in advanced settings of 802.1x windows supplicant ?
How do you configure supplicant ? Manual or GPO ?
If you can share screenshot from configuration supplicant.
Regards
Piotr Filip
Piotr Filip
Original Message:
Sent: Mar 20, 2024 02:55 PM
Hello Guys, I would like to some guidance in implementing EAP- Teap Method.
I have seen a lot of threads concerning TEAP method but so far nothing seem helpful. I have followed this guide:
But my problem is that the before the user login the computer is authenticated correctly but after the user login the TEAP method does not fall over the second method.
I have to disconnect and rejoin the network for fall back to method 2.
I have tried a lot of things but nothing seems to work.
Any help would me appreciated.
