ClearPass posture with Comware switches
  • 1.  ClearPass posture with Comware switches
    Posted Mar 06, 2024 10:06 PM
    Dear Experts,
    we are working with a customer who has implemented static IPs and Vlans. They want to authenticate via CPPM (-> AD) only and also do posture checking. Since dynamic vlans from CPPM are not configured what is the alternate way to restrict access if client device is unhealthy or unknown? do we need to implement acls?
    iqbal
  • 2.  RE: ClearPass posture with Comware switches
    Posted Mar 07, 2024 02:17 AM
    Hi Iqbal
    I do not know so much about Comware switches, but as you already guessed you are a bit limited in what actions you can implement in your environment.
    But ACL on the switch and sending the ACL ID in an attribute from ClearPass to the switch should work.
    Please check out this thread: https://community.arubanetworks.com/discussion/dynamic-acl-with-clearpass-and-comware-switches
    Best Regards
    Jonas Hammarbäck
    Aranya AB
