ClearPass Profiling - Manual Updates
  • 1.  ClearPass Profiling - Manual Updates
    Posted Nov 29, 2017 03:08 PM
    A couple questions regarding ClearPass and it's fingerprinting.
    1. If I have a device show up as Generic category, but an OS Family that I have other devices matching, if I manually update their fingerprint, that shouldn't cause any issues with other devices correct?
    Example: Device A profiled as Generic, OS Family is Axis. I have other Axis devices classified as IP Cameras. If I update the Generic ones to IP Cameras as their category, that shouldn't cause any issues with any other profiles correct?
    2. If I have (2) different devices that send similar or exact same DHCP options, and I manually update the fingerprint on one, could that affect the others as well with the same DHCP options?
    Example: Windows Computer and Medical Device running Windows-based OS both show up as Windows Computer. If I update the Medical Device, could that affect all fingerprinted Windows Computers?
    Thanks.
  • 2.  RE: ClearPass Profiling - Manual Updates
    Posted Nov 30, 2017 04:12 AM
    Good q.
    I'll be happy if someone will answer it.
