Could it be that under Device Setup / Discover, you configured discovery scans? Those will do a credential scan with the default credentials and may be what you see.
Original Message:
Sent: Aug 04, 2022 04:12 PM
Subject: ClearPass REJECT
You are right. I went under Communication and selected edit for "aruba" from default credentials list and I see that there is a telnet/SSH username "admin". What is the purpose of this account? How do I stop this from querying the Mobility Conductor?
Peter
Original Message:
Sent: Aug 04, 2022 04:04 PM
Someone must have configured Airwave to query the Mobility Conductor with the account "admin". This can be found under the communication settings in airwave. This must be hitting a service that is not created to handle logins from airwave.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
Original Message:
Sent: Aug 04, 2022 03:53 PM
The alert message is "user not found". But I'm trying to understand if/why Airwave is trying to access Mobility Master with an admin account. As mentioned, the End-Host is the Airwave server and the Access device is the Mobility master.
Original Message:
Sent: Aug 04, 2022 03:29 PM
Could you share more? Perhaps screenshots of the access tracker records?
Dustin Burns
Original Message:
Sent: Aug 04, 2022 03:26 PM
I am seeing multiple REJECT messages in Asset Tracker. The end-host Id is the Airwave server IP address and the Access device is the Mobility Master. The username is admin. If Airwave trying to connect to Mobility Master using an admin account?
