1. If you run any less it will not be supported by TAC
2. The 25K appliances are running at 4 Tera. We are asking for 1/4 of that.
3. If you have 25,000 devices connecting then you will need to have HD space for the
a. historical Data
b. Access Tracker Logs
c. Audit information
d. Guest information
e. User information
f. Certs
g. and many more.
With all that data the drives will fill up and the system will lock up. We are trying to actively help prevent you from having to call TAC.
If hard drive space is an issue I would suggest that you work with your local sales team to look into the Clearpass Appliance instead of a VM.
