it is supported for both and the approach is the same.
Original Message:
Sent: Jun 09, 2025 11:45 PM
Subject: ClearPass SPAN for Profiling
Thank you , is this only possible on Hyper-V? Or this also supported on VMware ?
Original Message:
Sent: Jun 09, 2025 11:36 PM
one needs to create a virtual switch and attach a ClearPass SPAN virtual interface to the virtual switch.
Here is how to configure SPAN for Hyper-V
Original Message:
Sent: Jun 09, 2025 07:58 PM
https://arubanetworking.hpe.com/techdocs/NAC/clearpass/platform/service-routing/
We allow the configuration of a dedicated SPAN port on one of the two spare Ethernet port on the onboard 4-port card. This allows us to ingest DHCP Discover and Request packets for profiling, this helps remove the requirement to configure DHCP IP helpers across the entire network.
ACEX #137
Original Message:
Sent: Jun 09, 2025 07:17 PM
any documentation that reflects that ? , i couldnt find any
Original Message:
Sent: Jun 09, 2025 04:44 PM
Yes
ACEX #137
Original Message:
Sent: Jun 09, 2025 02:45 PM
Is it possible and supported to use ClearPass (virtual or hardware) for device profiling using a SPAN port?
