I don't have experience, but with SAML, the communication goes through the end-user browser, which means that if ClearPass as SP works, and access to your IdP works, there should not be an issue.
Have you checked if it works without Webseal?
If you are using SAML indeed, there is a (Chrome) addon called SAML Tracer that shows the communication. I would expect the support of Trustbuilder to be able to assist in troubleshooting, or while I would use it as a fallback, Aruba support.
Original Message:
Sent: Nov 02, 2021 09:56 AM
Subject: clearpass SSO integration with Webseal & Trustbuilder
Hi
We need to integrate clearpass as SP (Service Provider) for SSO with trustbuilder . An additional problem is that the guest environment of Clearpass should be behind Webseal, so this complicates the setup of SSO . Putting CP behind Webseal does work, i was just wondering if anyone here had experience with the setup of SSO in Trustbuilder .
We tried several combinations, but none really works. Any experience ?
Danny Bosman
KBC Group - Belgium
