Clearpass TACACS Accounting Not Working
  • 1.  Clearpass TACACS Accounting Not Working
    Posted Nov 14, 2016 12:16 PM
    Scenario:
    When a user logs into a switch locally (off network) with local credentials, and then reconnects the switch to the network, the switch isn’t forcing the user to login via TACACS credentials. It still allows the local user to run commands. It is the same switch TACACS configuration we were using with ACS.
    Switch TACACS config:
    aaa new-model
    tacacs server CPPM-1
    address ipv4 1.1.1.1
    key 7 xxyyzz
    tacacs server CPPM-2
    address ipv4 2.2.2.2
    key 7 xxyyzz
    aaa authentication login default group CPPM-Servers local
    aaa authentication enable default group CPPM-Servers enable
    aaa authorization exec default group CPPM-Servers if-authenticated
    aaa authorization config-commands
    aaa authorization commands 1 default group CPPM-Servers if-authenticated
    aaa authorization commands 15 default group CPPM-Servers if-authenticated
    aaa accounting exec default start-stop group CPPM-Servers
    aaa accounting commands 1 default start-stop group CPPM-Servers
    aaa accounting commands 15 default start-stop group CPPM-Servers
    aaa accounting update periodic 5
    no tacacs-server directed-request
    ip tacacs source-interface Loopback0
    aaa group server tacacs+ CPPM-Servers
    server name CPPM-1
    server name CPPM-2
