Aruba Apps
Aruba Apps board is designed for questions, comments, and feature requests for all of Aruba Networks' mobile Apps.
Clearpass - "Dell" is not listed among vendors when adding a device
  • 1.  Clearpass - "Dell" is not listed among vendors when adding a device
    Posted Aug 19, 2022 10:49 AM
    I'm adding some Dell switches to Clearpass for TACACS access (Configure => Network => Devices) and found that "Dell" isn't listed in the "Vendor" dropdown menu. The specific devices are Dell EMC S5232F-ON, S5248F-ON and S3048-ON. I believe the OS they use is Force10 (DNOS 9.x).
    Has anyone added similar Dell switches to Clearpass? If so, which vendor selection was used?
    Thanks!
    Clearpass device config screenshot
  • 2.  RE: Clearpass - "Dell" is not listed among vendors when adding a device
    Posted Aug 22, 2022 04:45 AM
    According to this post, Dell doesn't use any vendor specific attributes so you can go for Vendor: IETF.
    If there would have been a Dell dictionary, you probably should have enabled it first under Administration -> Dictionaries -> RADIUS. Only specific vendors are enabled there to keep the Vendor drop-down menu clean.
  • 3.  RE: Clearpass - "Dell" is not listed among vendors when adding a device
    Posted Aug 26, 2022 05:49 PM
    I'll try IETF, I checked the Administration -> Dictionaries -> RADIUS section and found no listing for "Dell".
    Thanks!
