Check
show auth-tracebuf | inc <mac address> command in NAD device to see exactly where the request is getting timeout and also s
how aaa authentication-server radius statistics to verify average response times should be below 100ms and the timeouts should not be incrementing.
Note: set logging level debugging user-debug <mac address>
after debug disable it config t no logging level debugging user-debug <mac-address>
Pavan Arshewar
Principal Network Engineer
If my post addresses your query, give kudos!
Original Message:
Sent: Mar 07, 2022 07:47 PM
Subject: Clearpass Timeout Errors 9002
Hi, did you ever get it solved?
I'm facing the issue only with computer authentication in wired and wireless, same clearpass version. Everything works fine with user authentication.
Ulises Cazares
Original Message:
Sent: Aug 20, 2018 11:44 PM
I am running Clearpass 6.7.4.107401. I am attempting to use computer
authentication with Windows 10 computers. I have disabled certificate validation on the clients. However I keep getting timeout errors for the clients though they eventually connect. The Clearpass Alert Message is: Error Code 9002 Error Message: Request timed out
RADIUS Client did not complete EAP transaction. I also have the following errors in the log file:
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Deleting request sessid - R0003fda7-03-5b7b7d14, state - ABcAqgCQAK/GCSQA30wixKqlJBxMBFZ5HU8bEQ= |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 215:228:88:E4A47117479C recv 1534819604.599297 - resp 1534819604.613530 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 125:408:1124:E4A47117479C recv 1534819604.617075 - resp 1534819604.621863 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 62:244:1120:E4A47117479C recv 1534819604.739302 - resp 1534819604.740486 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 186:244:1120:E4A47117479C recv 1534819604.743439 - resp 1534819604.744340 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 148:244:1120:E4A47117479C recv 1534819604.747679 - resp 1534819604.748825 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 70:244:316:E4A47117479C recv 1534819604.752327 - resp 1534819604.753051 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 212:374:139:E4A47117479C recv 1534819604.757981 - resp 1534819604.759589 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 16:244:122:E4A47117479C recv 1534819604.872631 - resp 1534819604.873551 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 72:301:166:E4A47117479C recv 1534819604.876787 - resp 1534819604.877831 |
2018-08-20 21:47:36,051 | [main SessId R0003fda7-03-5b7b7d14] ERROR RadiusServer.Radius - reqst_clean_list: Packet 20:355:164:E4A47117479C recv 1534819605.265 - resp 1534819605.5700 |
