.. for 6.12 specific, if you are doing anything with Azure/EntraID/Intune, go for 6.12 as it has big improvements.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Jun 15, 2025 10:34 PM
Subject: ClearPass Upgrade: Physical to Virtual – Onguard Agent Concerns
Hi Brendan.
No. You can't mix different versions. My comment was just on moving existing phy appliance to vm. To move from 6.10 to 6.11 or higher you need to create a new vm with 6.11 image and migrate config via backup/restore procedure as described in documentation.
Having vip address will help minimize disruptions on the network when you migrate vip address from old node to new one after or before migration.
6.11 is LSR version and 6.12 is SSR version. Usually in production you preffere LSR version except if you really need features from short version.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2025
Original Message:
Sent: Jun 15, 2025 07:24 PM
@GorazdKikelj is this actually possible ? Joining a 6.11.x or later node to an existing 6.10.x cluster I thought is not supported as I thought they must be the same major version.
@Mithran any reason you're choosing 6.11 and not 6.12? I'm in the same boat myself and curious.
Original Message:
Sent: Jun 13, 2025 03:10 AM
Hi @Mithran
Just add VM to the cluster as subscriber, promote it to standby publisher, define VIP address and make sure that clients are connecting via VIP address. Then you can shutdown old publisher and VM will become publisher and clients will connect over VIP address.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2025
Original Message:
Sent: Jun 13, 2025 03:01 AM
Hi All,
I'm planning to upgrade our ClearPass deployment from a physical appliance(6.10.8) to a virtual machine(6.11.*). As part of this upgrade, I have a question regarding the Onguard Agent installed on user machines.
Since we're currently using the persistent Onguard Agent, I'd like to understand what steps (if any) need to be taken on the client side when we migrate ClearPass. Specifically:
Will the existing agents automatically connect to the new virtual ClearPass server?
Do we need to update the agent configuration on each machine (e.g., IP or hostname)?
Is there a recommended approach for minimizing disruption during this transition?
Appreciate any insights or best practices from those who have performed a similar migration.
