last person joined: 11 hours ago
ClearPass wired dot1x or MAC auth on AP switchport
This thread has been viewed 26 times
  • 1.  ClearPass wired dot1x or MAC auth on AP switchport
    Posted Sep 14, 2022 10:53 AM
    I'm securing some switchport utilising 802.1X and MAC authentication. ClearPass is being used to profile the MAC auth devices. Some of the MAC auth devices are Aruba AP and some of the AP broadcast a number of SSIDs which utilise different VLAN, hence the switchport the AP is patched into is configured as a trunk.
    This post shows how to do this for ArubaOS switches. Any tips on how to do this on Comware 7 switches? Or CX switches?
    Cheers
    James
  • 2.  RE: ClearPass wired dot1x or MAC auth on AP switchport
    Posted Sep 15, 2022 06:17 AM
    check the wired policy enforcement technote as it covers AOS-S, CX , comware and Cisco switches.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00091135en_us
  • 3.  RE: ClearPass wired dot1x or MAC auth on AP switchport
    Posted Sep 15, 2022 06:32 AM
    Hi, I'm not sure that the solution guide shows how to secure a trunk port with an AP attached. Can you clarify which part shows that?
  • 4.  RE: ClearPass wired dot1x or MAC auth on AP switchport
    Posted Sep 15, 2022 07:14 AM
    it should be there somewhere.
    But for CX switches basically you can do it either with LUR or DUR.
    As an example using LUR, the main component of it is the "port-access role" , this is the user-role that is send from CPPM.
    so here in this example CPPM is sending Aruba-user-role = IAP-1x
    port-access role IAP-1x
        description LUR-for-IAPs
        associate policy InstantAP-Pol
        poe-priority critical
        auth-mode device-mode    <<<<
        trust-mode dscp
        vlan trunk native 20    <<<< IAP is on the native VLAN and the tagged VLANs are for the WLANs
    setting auth-mode = device-mode provides the ability that when the first client authentication on the port defines that access for all clients on that port. So, if there are additional clients on the same port, they 'piggyback' on the access of the first device.  so in most cases, if we authenticate the Instant AP, we don't want the switch to authenticate clients that are connecting to the AP because the AP already authenticated them
  • 5.  RE: ClearPass wired dot1x or MAC auth on AP switchport
    Posted Sep 15, 2022 07:40 AM
    That's great! Thank you.
    Any tips on how to do this on a comware 7 switch?
