As long as the APs support FTM responder (which should be any 5XX/6XX AP), they should support this. To use a combination of FTM and LCI to locate the client device, you would need at least 3 APs to get an accurate fix, just as you would with RSSI based multilateration on wifi or bluetooth - but flight time isn't affected by attenuation the way RSSI measurements are, so it would be considerably more accurate, especially farther out from the APs (because of inverse square law, RSSI becomes less accurate as distance increases, even with clear LOS, more so with attenuation in the way, like warehouse racks)
It's my understanding that the field is designed to be populated by the onboard GNSS receiver in the 6XX APs (for use by the frequency coordination process required for outdoor and high power on 6GHz).
Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or Aruba Networks. For official support, please contact your account team or TAC.
Original Message:
Sent: May 30, 2023 12:34 PM
Subject: CLI commands for setting static Location information in AP
The APs alone will not self-locate. It will require the upcoming "Auto AP placement" feature in Aruba Central Next Generation.
Until its available you can use the WifiRttLocator App and the WifiRttScan App to play with FTM location.
Jens
Original Message:
Sent: May 29, 2023 09:49 AM
Do you maybe know how many AP's we need for this to work? Is there a number how many 6xx series?
i have 3x635 in my lab and some 5xxx.
Would for example 3x505 and 1x635 work and self-locate?
Original Message:
Sent: May 26, 2023 09:23 AM
I also believe that the UXI agent for Zebra scanners explicitly supports this.
Original Message:
Sent: May 26, 2023 07:38 AM
I got information from TAC how to calculate and manually setup LCI coordinates for 5xxx series. I don't know if it can be shared here.
But basically calculation of location can be done like it is explained here: https://www.ietf.org/archive/id/draft-thomson-geopriv-3825bis-03.html
Once you have those values calculated, you feed that to AP, enable LCI advertisement and voila, you're up and running.
I am going to test this next week to see how it works. I will also connect to 635 and compare results.
Original Message:
Sent: May 25, 2023 10:36 AM
i have been looking and it is not documented anywhere.
Do we really have to contact Tech Support for every AP we want to configure or are these commands published somewhere?
from Aruba-Instant-8.11.0.0-User-Guide:
For APs lacking the capability to automatically generate location information, their location can be
manually configured. However, the static location information can be configured on the AP only using
the CLI. Please contact Aruba Technical Support to configure the location information on your AP for
LCI broadcast.
