Wired Intelligent Edge
  • 1.  CLI for Call detail recorder?
    Posted Jul 14, 2009 08:11 PM
    We're currently using Call detail records v6.0.22 for NBX
    Release 6.5.20 to export phone call statistics and store
    them in our SQL database for further consumption.
    Currently we're using the GUI to do that. It would be
    great if we were able to automate the process so that our
    DB stays up to date.
    Is there a command line interface utility that will be
    able to perform same thing as the GUI?
  • 2.  RE: CLI for Call detail recorder?
    Posted Jan 27, 2010 01:26 PM
    I use the VCX Call Reports app, v. R7.0.24...I'm sure the two are basically the same.  The backend is just an Access database.  You can set up an ODBC connection from your SQL database to the Access database (or just directly use the Access database.  Within the Call Reports preference settings, under Retrieval, you can set up Automatic Retrieval and specify how often you want data retrieved.
    Hope that helps!
    I know your posting is from last year, but I am new and did not see a reply on your inquiry.
    Have a great day!
