Network Management
  • 1.  Click on "Modify Display Indexes" throws an java exception
    Posted Oct 28, 2016 08:39 AM
    Hi, all!
    iMC PLAT 7.2 (E0403P06) (Standard Edition, Linux). When I try to click "Modify Display Indexes" I immediately get a pop up error window with url something like: https://xxx.xxx.xxx:8443/imc/perfm/extend/perfDetailTaskList.jsf?devId=2097 and with "Errors Detail" like:
    javax.el.PropertyNotFoundException: Property 'perfSysParaMgr' not found on type com.h3c.imc.perfm.extend.view.PerfExtendTaskBean
    at javax.el.BeanELResolver$BeanProperties.get(BeanELResolver.java:290)
    at javax.el.BeanELResolver$BeanProperties.access$300(BeanELResolver.java:243)
    at javax.el.BeanELResolver.property(BeanELResolver.java:377)
    What does this error mean? And how to fix this problem?
    TIA,
    Sergei
  • 2.  RE: Click on "Modify Display Indexes" throws an java exception
    Posted Oct 28, 2016 02:44 PM
    Hi, all!
    Upgrading from E0403P06 to E0403P10 corrected the problem with java exeption while click "Modify Display Indexes". But a new problem is appeared: widget 'Important Devices' stopped to work - now it just a blank window, regardless of the number of the selected devices. Miracle :)
    WBR,
    Sergei
  • 3.  RE: Click on "Modify Display Indexes" throws an java exception
    Posted Nov 03, 2016 01:25 AM
    Hi, all!
    Miracles continue - IMC v7.2 E0403P10 did not work properly: every time after IMC-host was rebooted, within few hours fully stopped coming events from the monitored equipment (counters in status bar in low left corner are "frozen", no any e-mail alarms on critical alarms etc). And stopped to work widget 'Important Devices' - it became empty.
    In /opt/iMC/client/log/imcforeground.log file I found an error:
    java.lang.OutOfMemoryError: GC overhead limit exceeded
    In accordance with the recommendations from the document "H3C IMC Platform Troubleshooting Guide" I have increased Max Heap memory size first from current 2048 to 3072 then from 3072 to 3584 (further increase can't be - no more available RAM) but it did not help: about two o'clock in the morning, this error appeared again in the log.
    As a result, I had to revert back to the version E0403P06 - and these problems have disappeared. But came back the problem with non-working link "Modify Display Indexes" (java exeption).
