Client disconnects randomly
This thread has been viewed 42 times
  • 1.  Client disconnects randomly
    Posted Jan 31, 2018 03:35 AM
    Hi i have an issue where some users get disconnected randomly even when not roaming.
    i get this message while debugging the users, can anyone tell me what it means?
  • 2.  RE: Client disconnects randomly
    Posted Jan 31, 2018 03:50 AM
    and here is the trail-info.
    (DPPSMWC01-B1-GF-SR) #show ap client trail-info 48:13:7e:2d:30:01
    Client Trail Info
    MAC                BSSID              ESSID            AP-name                      VLAN  Deauth Reason                 Alert
    48:13:7e:2d:30:01  44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  STA has roamed to another AP  STA has roamed to another AP
    Deauth Reason
    Reason                                            Timestamp
    STA has roamed to another AP                      Jan 31 16:41:39
    Requested authentication algorithm not supported  Jan 31 16:40:46
    Sapcp Ageout (internal ageout)                    Jan 31 16:40:10
    Requested authentication algorithm not supported  Jan 31 16:33:51
    Requested authentication algorithm not supported  Jan 31 16:33:28
    Requested authentication algorithm not supported  Jan 31 16:33:06
    Requested authentication algorithm not supported  Jan 31 16:32:43
    Requested authentication algorithm not supported  Jan 31 16:32:30
    Sapcp Ageout (internal ageout)                    Jan 31 16:30:12
    Num Deauths:10
    Alerts
    Reason                        Timestamp
    STA has roamed to another AP  Jan 31 16:46:41
    STA has roamed to another AP  Jan 31 16:46:30
    STA has roamed to another AP  Jan 31 16:46:01
    STA has roamed to another AP  Jan 31 16:45:49
    STA has roamed to another AP  Jan 31 16:44:07
    STA has roamed to another AP  Jan 31 16:43:57
    STA has roamed to another AP  Jan 31 16:41:26
    STA has roamed to another AP  Jan 31 16:40:59
    STA has roamed to another AP  Jan 31 16:40:46
    STA has roamed to another AP  Jan 31 16:40:31
    Num Alerts:10
    Mobility Trail
    BSSID              ESSID            AP-name                      VLAN  Timestamp
    44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  Jan 31 16:46:41
    44:48:c1:08:b0:00  Courtyard_GUEST  DPSSMAP03-BASEMENT-BOH-ENG   1000  Jan 31 16:46:41
    44:48:c1:08:b0:00  Courtyard_GUEST  DPSSMAP03-BASEMENT-BOH-ENG   1000  Jan 31 16:46:30
    44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  Jan 31 16:46:30
    44:48:c1:08:ac:e0  Courtyard_GUEST  DPSSMAP11-BASEMENT-BOH-ENG2  1000  Jan 31 16:46:01
    20:a6:cd:fe:86:a0  Courtyard_GUEST  DPSSMAP01-GF-B1-LOBBY1       1000  Jan 31 16:46:01
    20:a6:cd:fe:86:a0  Courtyard_GUEST  DPSSMAP01-GF-B1-LOBBY1       1000  Jan 31 16:45:49
    Num Mobility Trails:10
  • 3.  RE: Client disconnects randomly
    Posted Jan 31, 2018 04:32 AM
    What kind of device is this?
    What Operating System Version?
    What encryption if any is being used?
  • 4.  RE: Client disconnects randomly
    Posted Jan 31, 2018 05:33 AM
    Hi Colin,
    the one being debug is an android but customer also report seeing this behaviour in apple devices.
    ArubaOS ver 6.5.2.1, i will suggest them to upgrade if we cannot make any sense from the log.
    open encryption.
  • 5.  RE: Client disconnects randomly
    Posted Jan 31, 2018 05:43 AM
    Is the client using 20/40 or 80 mhz channels?
    Do they have "Drop Broadcast and Multicast" enabled on all of their Virtual APS?
  • 6.  RE: Client disconnects randomly
    Posted Jan 31, 2018 06:07 AM
    all 20. i turned off all channel bonding.
    "Dynamic Multicast Optimization", "Drop Broadcast and Unknown Multicast", and "Convert broadcast arp to unicast" are all enabled
  • 7.  RE: Client disconnects randomly
    Posted Jan 31, 2018 06:17 AM
    What is the ARM Min/Max transmit power configured?
  • 8.  RE: Client disconnects randomly
    Posted Jan 31, 2018 06:34 AM
    5GHz at 12 to 18
    2.4GHz at 9 to 15
  • 9.  RE: Client disconnects randomly
    Posted Jan 31, 2018 06:43 AM
    You should enable user debugging to see why your clients disconnect.
    EDIT: You already did that..
    Looking at the debug, it says that your client just ages out (does not respond).  You should open a TAC case so that they can gather more detailed information.
  • 10.  RE: Client disconnects randomly
    Posted Jan 31, 2018 10:30 PM
    alright i'll do that.
    also, they are using RAP bridge mode, does that affect the client connection and roaming quality?
  • 11.  RE: Client disconnects randomly
    Posted Jul 25, 2018 11:05 AM
    GM Ricky,
    Did you find a resolution to this issue? We are having the same issue now with two Microsoft Surface laptops.
    Thank you
  • 12.  RE: Client disconnects randomly
    Posted Jul 25, 2018 10:50 PM
    Hi Tom,
    I do not remember what specificly i did but yes it was solved. you should check the interference level, how many APs in a area which could be too many or too far away (in-consistent distant between each AP but using same power profile could cause some problem), BC/MC optimization (don't forget on the wired side), and i believe i turned the 802.11h on.
    hope it helps. debugging a specific mac address should also help.
  • 13.  RE: Client disconnects randomly
    Posted Jul 31, 2018 06:14 AM
    Hi
    You might want to upgrade.
    There was similar problems with surface machines in particular, but it did affect other devices as well.
    Have a look at this thread.
    https://community.arubanetworks.com/t5/Wireless-Access/surface-device-disconnection-issues/td-p/305219/page/3
    I had a customer with the same problem on surface devices, after upgrade the devices behaved as expected.
    You should look into upgrading to 6.5.3.3 og 6.5.4.2
    At the moment 6.5.4.8 is the latest on 6.5 and it's marked as conservative, so you should be pretty safe.
    Roar
