Become a Member
Hi
We originally had band steering set and disabled load balancing as was recommending 5 years ago, we also have N off for 2.4Ghz.
Now we have upgraded the OS to 6.4 should we be using Client Match? Should I now turn off band steering and enable load balancing or will Client Match overide these settings?
Should I now allow N for 2.4Ghz?
Many thanks
I am not sure why it was setup that way originally?
Profiles - RF Management - 802.11g radio - N-off - ARM - single-band - a-only
Should i remove N-off?
This is enabled in the HT SSID Profile and Radio Profile
We have laptops, Tablets, Ipads and Iphones.
Laptops connect to the domain via VPN, other devices including guests connect through captive portal.
145 WAP's, can be around 250 devices.
