  • 1.  Client Match settings and local probe request threshold
    Posted Jan 13, 2014 03:33 PM
    The 6.3x user guide states the following:
    "When client match is enabled on 802.11ncapable
    access points, the client match feature overrides any settings configured for the legacy bandsteering, station
    handoff assist or load balancing features."
    Does this include the  local probe request threshold in the SSID profile?
    Is there a doc somehwere that lays out exactly what is enabled when you turn on client match?
  • 2.  RE: Client Match settings and local probe request threshold
    Posted Jan 13, 2014 04:05 PM
    The local probe request threshold parameter is honored, even if you have client match enabled.  There is nothing that says exactly what is enabled besides the statement above.  Maybe that statement should be more succint.
  • 3.  RE: Client Match settings and local probe request threshold
    Posted Jan 13, 2014 04:09 PM
    Ok thanks. I did find this article https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Client-Match-configuration-related-to-Sticky-Clients-AOS-6-3-and-above
    So that doc states:
    • Client Match Sticky client check SNR (dB) - If client's SNR drops below 25, then controller will search for a better candidate AP. Default is 25.
    But that is configured in the ARM profile, not SSID. So I would think you would want both the local probe request threshold = client match stick SNR?
  • 4.  RE: Client Match settings and local probe request threshold
    Posted Jan 13, 2014 04:11 PM
    So that doc states:
    I would turn on ClientMatch by itself and leave everything else to the defaults.  If the client's SNR drops below 25, the controller will search for a better candidate, but it must be at least 10 better than the one it is connected to by default.  Configuring local-probe request threshold adds complexity to this and should be left at zero.
  • 5.  RE: Client Match settings and local probe request threshold
    Posted Jan 13, 2014 05:16 PM
    We're an all wireless office running MS Lync and enabled a local probe threshold of 25.  We were advised to do this by an Aruba corp engineer we had on site recently.  The suggestion may have been based on our specific environment so I wouldn't necessarily advise anyone else do this unless instructed to.  That being said, we haven't noticed any issues - yet.
  • 6.  RE: Client Match settings and local probe request threshold
    ClientMatch overrides the following :
    - Band Sterring
    - Spectrum Loadbalancing
    (HOME-MASTER-CONTROLLER) #show rf arm-profile HOME-ARM-11a-PROFILE
    Adaptive Radio Management (ARM) profile "HOME-ARM-11a-PROFILE"
    Parameter        Value
    Assignment        single-band
    Allowed bands for 40MHz channels                                             a-only
    80MHz support        Enabled
    Client Aware        Enabled
    Max Tx EIRP        15 dBm
    Min Tx EIRP        9 dBm
    Rogue AP Aware                                                               Disabled
    Scan Interval        10 sec
    Aggressive scanning                                                          true
    Active Scan        Disabled
    ARM Over the Air Updates                                                     Enabled
    Scanning        Enabled
    Multi Band Scan                                                              Enabled
    VoIP Aware Scan                                                              Enabled
    Power Save Aware Scan                                                        Disabled
    Video Aware Scan                                                             Enabled
    Ideal Coverage Index                                                         10
    Acceptable Coverage Index                                                    4
    Free Channel Index                                                           25
    Backoff Time        240 sec
    Error Rate Threshold                                                         50 %
    Error Rate Wait Time                                                         30 sec
    Channel Quality Aware Arm                                                    Disabled
    Channel Quality Threshold                                                    70 %
    Channel Quality Wait Time                                                    120 sec
    Minimum Scan Time                                                            8
    Load aware Scan Threshold                                                    1250000 Bps
    Mode Aware Arm                                                               Disabled
    Scan Mode        all-reg-domain
    Cellular handoff assist                                                      Disabled
    Client Match        Enabled
    Client Match report interval (sec)                                           30
    Allows Client Match to automatically clear unsteerable clients after ageout  Enabled
    Client Match Unsteerable Client Ageout Interval                              2 0
    Client Match Sticky Client Check Interval (sec)                              3
    Client Match Sticky client check SNR (dB)                                    25
    Client Match SNR threshold(dB)                                               10
    Client Match Sticky Min Signal                                               70
    Client Match Restriction timeout (sec)                                       10
    Client Match Load Balancing threshold (%)                                    20
    Client Match VBR Stale Entry Age (sec)                                       120
    Client Match Max steer failures                                              3
    Client Match Load Balancing client threshold                                 10
    Client Match Load Balancing SNR threshold (dB)                               30
    You can adjust some of the ClientMatch thresholds
    SNR
    Load balance
    And the Max signal you want your devices to get steer to another AP
  • 7.  RE: Client Match settings and local probe request threshold
    Posted Jan 13, 2014 06:04 PM
    Thecompnerd,
    You are right. It is certainly individual.
  • 8.  RE: Client Match settings and local probe request threshold
    Posted Jan 13, 2014 06:25 PM
    Another thing to note is that the sticky client functionality of client match helps clients roam/move to better AP's, whereas the local-probe threshold feature makes sure that the AP does not encourage clients to connect with probe requests below SNR of the configured value.  Client match is configured in the ARM profile, and so is applied to the radio - regardless of SSID.
    I agree that the recommendation is to leave local probe threshold in SSID profile as 0 (disabled) unless suggested by TAC based on deployment/need.
