Could it be that you have Role Assignment in your SSID configuration? It may be that there is a role assignment that for specific device types changes the role, that may happen in the middle of the session. I would make sure there are no VLAN Assignment Rules and no Role Assignment Rules to start with. Then just use the Aruba VSAs: Aruba-User-Role and Aruba-User-VLAN, which are both applied even if there are no assignment rules.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Jan 03, 2025 01:25 PM
Subject: Clients are reverting to SSID role after some minutes
Hi there,
Currently facing an issue where some clients will receive a role from ClearPass (aruba-user-role VSA), apply it but after some minutes get into the SSID role.
There is no activity on ClearPass other than Accounting-Stop and Accounting-Start (with a new session-id) when this happens. No Access-Req is present.
- Client connects; ClearPass answers with aruba-usr-vsa = user-role; IAP shows role = user-role for the client
- Then, after some minutes, client role becomes equal to the SSID name
- Disconnecting the client (trashcan icon in client list) forces a new reauth and the role gets again equal to user-role
- But then again after some minutes ir reverts back to SSID name
Any idea what can be the issue here?
