  • 1.  Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 11, 2016 12:09 AM
    Folks,
    Our users are having to reauthenticate themself on the Wireless network which comprises of 2 IAP-225 in cluster.
    We actually use a certificate based authentication wherin the pop up to accept the certificate keeps happening to the users many times a day.
    What do you suggest to check? or what could be the issue?
    N.
  • 2.  RE: Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 11, 2016 12:18 AM
    When did this first start happening?
    How many times a day does it happen?
    What radius server are you using?
    Who configured the radius server and Instant?
  • 3.  RE: Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 11, 2016 01:17 AM
    Hi Colin,
    Here are the answers
    This is happening since the Aruba IAP-225 cluster has been deployed and folks are connecting to the. Initially we had the Cisco solution in place which has been replaced with the Aruba.
    This happens like more than 10 times a day. People get irritated and then switch to the LAN.
    This is service on the Cisco ACS, which forwards certificate credentials to the Microsoft server.
    We did this.
    Thanks.
    N.
  • 4.  RE: Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 11, 2016 05:41 AM
    Thank you.  If you can, please get the tech support from the VC and PM it to me:
    Go to Support> AP Tech Support Dump > Run
  • 5.  RE: Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 13, 2016 11:00 PM
    What client operating systems are experiencing this?
  • 6.  RE: Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 15, 2016 02:11 AM
    The Windows an Apple OS systems are facing these disconnects.
  • 7.  RE: Clients facing reauthentication issue on IAP-225 network.
    Posted Mar 15, 2016 08:24 AM
    @network_geek1979 wrote:
    Do you have "Broadcast Filter ARP or Broadcast Filter All" on all of your SSIDs?
    What is width of your channels on the 5ghz band?
    Are you using DFS?
    Under ARM what is your maximum and minimum transmit power?
