  • 1.  Cluster with two geographic locations?
    Posted Oct 25, 2018 04:54 AM
    Hi there,
    I have two different locations that are connected by a VPN link.
    I want both locations to work even if the other side goes down.
    I'm unsure what should I do?
    # Publisher + Subscriber?
    Will subscriber authenticate users when publisher is down?
    Will OnGuard work? (requires health to be written to db?)
    Will [Machine Authenticated] work for new machines? (requires role to be written to db?)
    # Publisher + Standby Publisher?
    if the link goes down, both Publishers will become active. What happens when the link goes up again?
    Can I do automatic failback so that after the link comes up the promoted publisher gets back to standby?
    Another related question:
    Will data that I insert to the database using appexternal also get replicated from Publisher to Subscribers?
  • 2.  RE: Cluster with two geographic locations?
    Posted Oct 26, 2018 11:57 AM
    Related:
    - Is it possible to have centralized accounting on the Publisher?
  • 3.  RE: Cluster with two geographic locations?
    Posted Oct 27, 2018 03:40 PM
    This interests me too. We have two separate locations too so can't have virtual IP for Clearpass servers.
    Wondering also if I should relay DHCP to both servers or will it mess up the profiling?
  • 4.  RE: Cluster with two geographic locations?
    Posted Nov 01, 2018 09:32 PM
    Please take a read of the following document.
    CPPM TechNote - Clustering Design Guidelines v1.2
    This should help you out with the information you are looking for.
    thanks,
