CoA (Bounce) not working on HP 2620 switches
This thread has been viewed 37 times
  • 1.  CoA (Bounce) not working on HP 2620 switches
    Posted 27 days ago
    Hello
    I have a problem with HP2620 POE switches which do not accept CoA (bounce). The configuration in CPPM is good because other AOS switches are working fine! I have already brought the switch to the latest possible firmware "RA16.04.0028".
    Within ClearPass I get the message "Unsupported attribute"
    Are these 2620 switches too old for this?
    I see that in similar issues on this topic often is asked if a VIP IP address is used.
    In this case, I am also using a VIP.
    What could be or is the problem?
    HP 2620 POE switch Unsupported Attribute
  • 2.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 27 days ago
    You are sending a Bounce Message which the 2620 is not understanding (is not in the attribute library) and that is the reason why you see this message.
    I think you need to add Vendor-Specific = "HP,255 = 'BOUNCE_PORT'"  because that is the correct message that it is expecting for it to work
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 26 days ago
    Hello Shpat
    Thanks for you reply!
    Can you tell me where I do need to add those Vendor-Specific values?
    Is this in Radius Dynamic Auth Templates?
    Also I created a HP 2620 specific Enforcement profile with some added information which I found in the discussion forum for 2920 Switches.
    But that was not the solution!
    Kind regards,
    Jan
  • 4.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 26 days ago
    You need to create a new dictionary and check the mandatory AVP Pairs necessary to perform VLAN Change or Port Bounce.
    Then when you add the Device in ClearPass, you choose that specific template for that device.
  • 5.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 19 days ago
    Hello Shpat,
    Earlier you mentioned, "I think you need to add Vendor-Specific = "HP,255 = 'BOUNCE_PORT'"
    I tried editing the original HP radius template and adding your suggestion and then importing it back again, but that didn't succeed. I get an error everytime saying that the XML file is not valid...
    Also, you mentioned the ID:255, but that one is already in the existing Radius template.
    Afbeelding met tekst, schermopname, Lettertype, ontwerp
Door AI gegenereerde inhoud is mogelijk onjuist.
    I have never added an extra line to an existing template or imported a completely new template.
    I searched the Internet for Port bounce attributes for an HP2620 switch but I cannot find it.  However, I did find an alternative way for adding VSA for port bounce:
    Afbeelding met tekst, schermopname, software
    Only I don't have the option "RADIUS Vendors", and can only use import/export.
    Any help would be appreciated!
    Jan
  • 6.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 19 days ago
    I believe you should create a new RADIUS Dynamic Authorization Template for 2620 with correct attribute.
    Export standard ArubaOS - Bounce Switch Port entry and modify it with correct values.
    Untested as I don't have any 26xx available.
    <TipsContents xmlns="http://www.avendasys.com/tipsapiDefs/1.0">
    <TipsHeader exportTime="Thu May 29 09:53:28 CEST 2025" version="6.12"/>
    <RadiusCOATemplates>
    <RadiusCOATemplate vendorId="11" templateType="CoA" displayName="HP Switching - Bounce Switch Port" name="Port-Bounce-Host-HP">
    <AttributeList>
    <Attribute inputRequired="Not_Required" value="%{Radius:IETF:User-Name}" name="User-Name" type="Radius:IETF"/>
    <Attribute inputRequired="Not_Required" value="%{Radius:IETF:Calling-Station-Id}" name="Calling-Station-Id" type="Radius:IETF"/>
    <Attribute inputRequired="Not_Required" value="%{Radius:IETF:NAS-Port}" name="NAS-Port" type="Radius:IETF"/>
    <Attribute inputRequired="Not_Required" value="%{Radius:IETF:NAS-IP-Address}" name="NAS-IP-Address" type="Radius:IETF"/>
    <Attribute inputRequired="Required" value="%{Radius:IETF:Event-Timestamp}" name="Event-Timestamp" type="Radius:IETF"/>
    <Attribute inputRequired="Not_Required" value="255" name="BOUNCE_PORT" type="Radius:Hewlett-Packard-Enterprise"/>
    </AttributeList>
    </RadiusCOATemplate>
    </RadiusCOATemplates>
    </TipsContents>
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 7.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 15 days ago
    Hello Goradzd,
    Thanks for your response. I tried to modify the existing template with your suggestions. I think the Attribute "BOUNCE_PORT" is not correct, because I get an error message when importing.
    Afbeelding met tekst, elektronica, schermopname, software
  • 8.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 10 days ago
    Edited by GorazdKikelj 10 days ago
    Hi Jan.
    Yeah, I was afraid of that. Didn't have time to test it.
    Try with the following enforcement profile
    In quick search I couldn't find what specific RADIUS attributes are supported on 2620.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 9.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 5 days ago
    Hi Gorazd,
    Unfortunately still no success!
    I've asked HP support what radius attributes the HP2620 accepts!
    Jan
  • 10.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 5 days ago
    Hi Jan.
    :-( I'm still puzzled why standard bounce attribute is not recognized with 16.04 as FW version is relatively recent.
    Hopefully you'll get somebody from TAC to provide you with correct attributes. There is nothing in docs regarding COA attributes for 2620.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 11.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 4 days ago
    Hi Gorazd,
    Thanks for your help this far!
    I've contacted TAC, but they do not support the devices anymore...
    I don't know if there is a way that I can use to debug/analyze the switch and which can be used to figure out the correct attributes.
    Jan
  • 12.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 4 days ago
    I would play with custom CoA profile and try to find attribute that work. Unfortunately it will take time to do it.
    Try to find FreeRadius or other radius dictionaries from years back. I did look into FreeRadius and HP dictionary is mostly the same.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 13.  RE: CoA (Bounce) not working on HP 2620 switches
    Posted 4 days ago
    Maybe first try with just bare bone CoA enforcement profile attribute 12. It can be that some other attribute is failing.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
