To clear BIOS passwords you usually need to remove the BIOS battery, I know on older HP PAVILION NOTEBOOKS there is a certain key combination to remove the BIOS password. I would call COMPAQ TECH support and explain the situation to them and they should be able to help you..
Hope this helps.
