COMPAQ NETBEUI PATCH
  • 1.  COMPAQ NETBEUI PATCH
    Posted Mar 25, 2003 06:56 AM
    After installing the patch provided for supporting NETBEUI protocol on XP Pro I could not get my EVO 610c to establish a successfull TCP/IP connection to my ISP, the attempt resulting on a message prompting me that TCP/IP could not be installed properly...again, everything worked fine until the patch was installed. I even tried and uninstall the patch but that did not affect the behaviour of the machine. On the other side I can get a TCP/IP connection if using the XP dialer instead of the one provided by the ISP (AT&T Global Network) but I can not get any DNS server to work, resulting in an unusefull connection anyway. Any help would be appreciated. Thanks,
    Leo
