did you try the transcivers. Are they working together on the same line?
Regards
Tomas
Tomas Nohejl
Original Message:
Sent: Apr 17, 2019 06:43 AM
Subject: Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
I have to connect an 8320 with Aruba 40G QSFP+ LC BiDi 150m MMF (JL308A) with a Cisco Nexus which use the Cisco QSFP-40/100-SRBD transceiver.
Due to the datasheet the Aruba transceiver works with 850 nm
and Cisco works with 855 nm
Is it possible to build up a link between those transceiver?
Frank
