Hi
I am planing to migrate a warehouse to aruba models AP 304 from an older Enterasys Wifi solution.
The clients currently used in the warehouse is Falcon X3+ Handscanncers from Datalogic.
My experience from a former migration, is to check the clients compatiblity first.
Can anyone help with information how to check that this handscanner is compatible with Aruba ? Or do someone you have experience with Falcon Handscanners ?
I would like to be proactive and avoid problems with the clients after installation of Aruba.
Thanks in advance
Henrik
Some information about the device below:
Microsoft Windows CE 6.0 Professional with
MICROPROCESSOR XScale™ PXA310 @ 806 MHz
COPROCESSOR Cortex-M3, 32 bit
Laird/Summit IEEE 802.11 a/b/g/n
Frequency range: Country dependent, typically 2.4
GHz and 5.2 GHz; Cisco Compatible CCX v4 Security
