I am marking DSCP using an input QoS policy.
The details of the policy setup are irrelevant, a packet capture from a machine connected to the output port confirms that:
- packet DSCP is 0 by default (without the policy)
- DSCP changes to the desired value (cs6 in this case) when I apply the input policy.
However, when I run
display qos queue-statistics interface
on the output port (I should see prioritization of marked packets here) all queues counters are 0 except for queue 2.
My output port configuration is as follows:
interface GigabitEthernet1/0/10
port link-mode bridge
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan [list of VLANs]
flow-control
qos lr outbound cir 514560 cbs 16000000
qos trust dscp
I have also tried:
- without qos lr on the output port
- with wrr queueing discipline on the output port
- with remark local-precedence in the QoS policy
- with remark ip-precedence
- using remark dscp on an output rule instead of input
In all cases every queue statistic except queue2 stays 0.
I've been through the "H3C S5830 Switch Series ACL and QoS Configuration Guide" document and I don't see any other info on the topic.
Any clue or insight is much appreciated :)
My version information is as follows:
HP Comware Platform Software
Comware Software, Version 5.20.105, Release 1118P13
Copyright (c) 2010-2016 Hewlett-Packard Development Company, L.P.
HP A5830AF-48G uptime is 75 weeks, 6 days, 8 hours, 34 minutes
Slot 1 (M):
Uptime is 75 weeks,6 days,8 hours,34 minutes
A5830AF-48G with 1 Processor
1024M bytes SDRAM
64M bytes Nor Flash Memory
CPLD A Version is 005
CPLD B Version is NULL
BootWare Version is 1.06
[SubSlot 0] 48GE + 2COMBO SFP + 2SFP Plus
Hardware Version is REV.C
Patch Version : None
