Comware
  • 1.  comware and procurve bridge-aggregation vlan noobie question
    Posted Mar 16, 2015 10:34 AM
    Hi there. I probably missed a post with the answer when I searched for this but here I go.
    Background, I am used to procurve and now made the move to a new comware based core.
    My previous setup was a procruve connected to another procurve with LACP trunks with all vlan tagged on the trunk.
    The new setup with which I am having an issue is a procurve and comware connected to another with LACP.
    The trunk conf on procurve is straight forward:
    trunk J1-J4 trk60 lacp
    then this trk60 is tagged in each vlan of interest (1,99,100).
    The bridge aggregation on comware is also ok:
    interface Bridge-Aggregation10
    port link-type trunk
    port trunk permit vlan all
    link-aggregation mode dynamic
    And the interfaces of interest are in the bagg accordingly
    interface GigabitEthernet1/0/10
     port link-mode bridge
     port link-aggregation group 10
    You will note I am doing permit vlan all too.
    On the procurve, my LACP looks good.
              LACP      Trunk     Port                LACP      Admin   Oper
       Port   Enabled   Group     Status    Partner   Status    Key     Key
       J1     Active    Trk60     Up        Yes       Success   0        349
       J2     Active    Trk60     Up        Yes       Success   0        349
       J3     Active    Trk60     Up        Yes       Success   0        349
       J4     Active    Trk60     Up        Yes       Success   0        349
    On the comware, my BAGG also looks good
    Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing
    Port Status: S -- Selected, U -- Unselected
    Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
            D -- Synchronization, E -- Collecting, F -- Distributing,
            G -- Defaulted, H -- Expired
    Aggregation Interface: Bridge-Aggregation10
    Aggregation Mode: Dynamic
    System ID: 0x8000, 7848-5952-8f88
    Local:
      Port             Status  Priority Oper-Key  Flag
      GE1/0/10         S       32768    1         {ACDEF}
      GE1/0/11         S       32768    1         {ACDEF}
      GE2/0/10         S       32768    1         {ACDEF}
      GE2/0/11         S       32768    1         {ACDEF}
    Remote:
      Actor            Partner Priority Oper-Key  SystemID               Flag
      GE1/0/10         217     0        349       0xcf00, 0018-71ca-cf00 {ACDEF}
      GE1/0/11         219     0        349       0xcf00, 0018-71ca-cf00 {ACDEF}
      GE2/0/10         218     0        349       0xcf00, 0018-71ca-cf00 {ACDEF}
      GE2/0/11         220     0        349       0xcf00, 0018-71ca-cf00 {ACDEF}
    however...
    While everything connected on my procurve untagged on vlan 99 and 100 is fine and reach the comware, what is untagged on vlan 1 doesn't.
    now I perhaps lack comprehension of comware but here is what I think.
    on comware, if I look at vlan 99 and 100 I see that the BAGG (and the member ports) is tagged.
    >dis vlan 100
     VLAN ID: 100
     VLAN Type: static
     Route Interface: not configured
     Description: VLAN 0100
     Tagged   Ports:
        GigabitEthernet1/0/10    GigabitEthernet1/0/11    GigabitEthernet2/0/10
        GigabitEthernet2/0/11
        Ten-GigabitEthernet1/0/29
        Ten-GigabitEthernet1/0/30
        Ten-GigabitEthernet2/0/29
        Ten-GigabitEthernet2/0/30
     Untagged Ports: none
    but on vlan 1 the BAGG is untagged.
    >dis vlan 1
     VLAN ID: 1
     VLAN Type: static
     Description: VLAN 0001
     Tagged   Ports: none
     Untagged Ports:
        GigabitEthernet1/0/1     GigabitEthernet1/0/2     GigabitEthernet1/0/3
        GigabitEthernet1/0/4     GigabitEthernet1/0/5     GigabitEthernet1/0/6
        GigabitEthernet1/0/7     GigabitEthernet1/0/8     GigabitEthernet1/0/9
        GigabitEthernet1/0/10    GigabitEthernet1/0/11    GigabitEthernet1/0/12
        GigabitEthernet1/0/13    GigabitEthernet1/0/14    GigabitEthernet1/0/15
        GigabitEthernet1/0/16    GigabitEthernet1/0/17    GigabitEthernet1/0/18
        GigabitEthernet1/0/19    GigabitEthernet1/0/20    GigabitEthernet1/0/21
        GigabitEthernet1/0/22    GigabitEthernet1/0/23    GigabitEthernet1/0/24
        GigabitEthernet1/0/25    GigabitEthernet1/0/26    GigabitEthernet1/0/27
        GigabitEthernet1/0/28    GigabitEthernet2/0/1     GigabitEthernet2/0/2
        GigabitEthernet2/0/3     GigabitEthernet2/0/4     GigabitEthernet2/0/5
        GigabitEthernet2/0/6     GigabitEthernet2/0/7     GigabitEthernet2/0/8
        GigabitEthernet2/0/9     GigabitEthernet2/0/10    GigabitEthernet2/0/11
        GigabitEthernet2/0/12    GigabitEthernet2/0/13    GigabitEthernet2/0/14
        GigabitEthernet2/0/15    GigabitEthernet2/0/16    GigabitEthernet2/0/17
        GigabitEthernet2/0/18    GigabitEthernet2/0/19    GigabitEthernet2/0/20
        GigabitEthernet2/0/21    GigabitEthernet2/0/22    GigabitEthernet2/0/23
        GigabitEthernet2/0/24    GigabitEthernet2/0/25    GigabitEthernet2/0/26
        GigabitEthernet2/0/27    GigabitEthernet2/0/28
    so here I go, the issue seem to be that I have a BAGG with port-link mode trunk that is untagged? hence not getting my vlan 1 traffic from the procurve? if so how do I "tagged" my BAGG on vlan1?
    or perhaps I am mixing up the terms and miss something because when I had only procurve, this conf with the lacp trunk tagged on all vlans it did not require much more config.
    #comware
    #bagg
    #ProCurve
    #VLAN
  • 2.  RE: comware and procurve bridge-aggregation vlan noobie question
    Posted Mar 16, 2015 02:52 PM
    Hi Kitkatneko,
    I think you need to explicitly set another pvid. Otherwise vlan1 will be pvid. (untagged)
    so on your bagg do :
    port trunk pvid <some vlan you do not use>
    Then vlan 1 will not be untagged.
    Regards
  • 3.  RE: comware and procurve bridge-aggregation vlan noobie question
    Posted Mar 17, 2015 03:48 AM
    I agree, native vlan/PVID is untagged in Comware 802.Q trunk ports.
    You will need to set to another PVID if you want VLAN 1 to be tagged.
    Daryl
  • 4.  RE: comware and procurve bridge-aggregation vlan noobie question
    Posted Mar 18, 2015 09:56 AM
    I indeed totaly missed the PVID part.
    As mentioned I have changed the PVID of my BAGG and it automagically got tagged under the allowed vlan.
    Thank you.
