Comware
  • 1.  Comware emulator
    Posted Sep 22, 2014 10:14 AM
    Is this Comware Emulator work for HP ProCurve Switches? Looking for a tool that I can test on instead of my production equipment.
    -Scott
  • 2.  RE: Comware emulator
    Posted Sep 24, 2014 09:09 AM
    Scott,
    This emulator is based on our Comware operating system.
    Some of our later provision switches have comware compatible cli.
    So learning comware can help you support your provision switches.
    Andrew
  • 3.  RE: Comware emulator
    Posted Oct 28, 2014 09:52 AM
    Does anyone know if this emulator provides ability to support not only the Procurve line, but the 3Com devices?  Looking to find way to get NOC trained on the devices that in place from HP purchase of 3Com.
  • 4.  RE: Comware emulator
    Posted Oct 28, 2014 03:19 PM
    Hi JDeMo,
    All 3Com/H3C devices operate on the Comware OS, so this tool will be the best way to get the NOC trained on the 3Com devices.
    Jay
  • 5.  RE: Comware emulator
    Posted Nov 03, 2014 03:53 PM
    Jay,
    Thanks for the reply.  You mentioned all HP is run on the comware, but how about the older, tradition procurve?
  • 6.  RE: Comware emulator
    Posted Nov 03, 2014 04:06 PM
    Hi JDeMo,
    All of HP is not run on Comware, all of the 3Com/H3C devices run on Comware.
    The Procurve devices still use Procurve.
    The HNS simlulator simulates only Comware, not Provision.
    Jay
