Comware
  • 1.  Comware Voice VLAN & 802.1x
    Posted Jul 15, 2013 03:07 PM
    Does anybody know whether it is possible to implement 802.1X with dynamic VLANs AND a voice VLAN on the same interface, on an HP 5120-EI.
    Ideally I would like the following:
    Any port on a PoE switch may have:
    • A PC attached
    • A phone attached
    • A phone and a PC attached
    The PC traffic should enter a VLAN dynamically specified by RADIUS, and the voice data should go into VLAN 50.
    All phones are Cisco 7941s.
    Pete
    #VLAN
  • 2.  RE: Comware Voice VLAN & 802.1x
    Posted Aug 08, 2013 04:25 PM
    try this:
    port link-type hybrid
    port hybrid vlan 1 untagged
    voice vlan 5 enable ## 5 is my voice vlan. Replace with your voice vlan id.
    mac-vlan enable
    dot1x re-authenticate
    dot1x guest-vlan 3   ## 3 is my guest vlan. Replace with your GUEST vlan id.
    undo dot1x handshake
    undo dot1x multicast-trigger
    dot1x
    I've been using and it works. My switchs are 5500-ei.
    #dot1x
    #VoiceVlan
  • 3.  RE: Comware Voice VLAN & 802.1x
    Posted Aug 16, 2017 07:39 AM
    Hi Fabiano,
    Why  would you need a guest-vlan? Is it really needed for the 802.1x authentication?
