  • 1.  Concurrent Clients
    Posted Jun 18, 2014 03:01 PM
    We are currently using a controller with 6 associated AP's. One of our SSID's uses 802.1x and authenticates clients using the internaldb on the controller. We are wanting to limit the amount of concurrent devices that a user can have on at any time. Is there a way to do this? Any help would be appreciated!
    #ALE
  • 2.  RE: Concurrent Clients
    Posted Jun 18, 2014 03:42 PM
    You would need an external RADIUS server that can handle session accounting.
  • 3.  RE: Concurrent Clients
    Posted Jun 19, 2014 06:14 AM
    Thanks for the response!
    I have noticed that under the "User Roles" there is an option to restrict "Max Sessions".
    Would this not do what I am looking to achieve?
  • 4.  RE: Concurrent Clients
    Posted Jun 19, 2014 07:03 AM
    No. That limits the number of sessions tor each client device.
  • 5.  RE: Concurrent Clients
    Posted Jun 19, 2014 01:04 PM
    Ok, thanks for your help.
    Are you able to recommend a product?
  • 6.  RE: Concurrent Clients
    Posted Jun 19, 2014 01:05 PM
    Aruba ClearPass is generally recommended.
