Concurrent connections limit issue
  • 1.  Concurrent connections limit issue
    Posted Oct 16, 2015 04:03 AM
    hi,
    we have issue with limiting clinet device number,
    controller config:
    RFC--> cppm ip
    accounting -->cppm assigned
    cppm configuration:
    insight enabled
    service:
    mac cashing service:
    authentication source insight. endpoint repos,
    auth endpoint repos   unique device count grteater than 1 deny access profile
    ***issue is that unieuq device count doesnt increment when same username connected with 2 different device,
    do i need to sql command in side the insght?
  • 2.  RE: Concurrent connections limit issue
    Posted Oct 24, 2015 07:55 AM
    did you build the services yourself or via template? can you share how they look?
