  • 1.  Conductor upgrade
    Posted Aug 23, 2024 03:46 AM
    I upgraded Mobility Conductor and Controllers from 8.6.0.4 to 8.9.0.3 and now the Controllers are no longer communicating with the Conductors. The dashboard of the Conductor is only showing the Controllers but not the Access points or the WLANs details.Post
  • 2.  RE: Conductor upgrade
    Posted Aug 23, 2024 06:56 AM
    Any reason to upgrade to an unsupported release 8.9? I would upgrade to 8.10 first, then start troubleshooting.
    Bit confused as you mention that controllers are no longer communicating with the conductors, but also that they show in the conductor dashboard...
  • 3.  RE: Conductor upgrade
    Posted Aug 25, 2024 07:18 AM
    Execute show switches on the Mobility Conductor. What status and configuration state is displayed on the controllers?
    Execute show ap database on the Mobility Conductor. Are APs displayed? If so, with which status?
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
