Configuration Aruba 6100
This thread has been viewed 60 times
  • 1.  Configuration Aruba 6100
    Posted Oct 04, 2024 10:26 AM
    Hello.
    I have for the first time an Aruba 6100 and the configuration it's very not easy to understand.
    I would like to configure a vlan 100 for management mode untagged and other vlan with mode tagged. I don't find the hybrid mode same with old model.
    I configure the vlan 100 with mode trunk native-untagged. I configure the vlan 100 with IP 172.28.100.6/24 and all other vlan with mode tagged.
    If i configure an another port with the vlan xx untagged, the device receive ip. It's done.
    The problem is the switch it's not accessible and not ping to ip 172.28.100.6.
    In ssh mode (with computer connect to vlan 100 untagged to other port) the ping 100.6 done but not ping gateway 100.1 and not the second switch (Hpe also) in the same vlan 100.
    What configuration lose ? or where configure interface management or gateway ?
    I don't know it's same problem, i configure one port with Access Point with vlan wifi, the AP receive good IP and good vlan but the device receive the Vlan and IP 172.28.100.x
    Thanks.
  • 2.  RE: Configuration Aruba 6100
    Posted Oct 04, 2024 12:37 PM
    Are you asking how to configure the switch or how to configure the AP?
    Some examples of your existing configuration, maybe a diagram or what you are trying to achieve would be useful.
    Carson Hulcher, ACEX#110
  • 3.  RE: Configuration Aruba 6100
    Posted Oct 05, 2024 01:48 AM
    I suggest to configure a port to be access  vlan 100 and connect your device to it to see if it gets an IP address.
    here is the configuration for untagged VLAN
    interface x/y/z
        no shutdown
        no routing
        vlan access 100
  • 4.  RE: Configuration Aruba 6100
    Posted Oct 07, 2024 02:57 AM
    Hello.
    I configure the vlan 100 to an another port. i d'ont have ip (dhcp not ready) if i add ip manually it's working and i have access with my computer to web console or ssh. It's only problem with route to access management switch. If i test ping since console web to gateway 172.28.100.1 it's not responding.
  • 5.  RE: Configuration Aruba 6100
    Posted Oct 07, 2024 03:01 AM
    Hello. The first problem is to access switch management. I upload file with config vlan.
  • 6.  RE: Configuration Aruba 6100
    Posted Oct 07, 2024 03:29 AM
    if you can get it to work with a static IP address, it means that your DHCP scope is not configured or the server does not have a route back to it.
    what is the output of your "show ip route" ?
  • 7.  RE: Configuration Aruba 6100
    Posted Oct 07, 2024 04:28 AM
    I think it's the route but i don't know what i need to add or change.
    Config :
    172.28.100.0/24, vrf default
            via  vlan100,  [0/0],  connected
    172.28.100.6/32, vrf default
            via  vlan100,  [0/0],  local
    For dhcp it's not ready to this vlan i hope. If i connect computer with vlan 21 the dhcp working.
  • 8.  RE: Configuration Aruba 6100
    Posted Oct 07, 2024 05:48 PM
    you need to add appropriate routes to the default gateway (172.28.100.1) to be able to reach your dhcp server and then check the default gateway of the dhcp server and it should have a route to 172.28.100.0/24 as well.
  • 9.  RE: Configuration Aruba 6100
    Posted Oct 08, 2024 02:08 AM
    Why the gateway not respond when i ping since the switch 172.28.100.6 ? What's the command to add route ? I test add route ip 172.28.100.0/0 172.28.100.1 but not working.
  • 10.  RE: Configuration Aruba 6100
    Posted Oct 08, 2024 05:51 PM
    you can find the user guides for 6100 switches from here
  • 11.  RE: Configuration Aruba 6100
    Posted Oct 11, 2024 10:20 AM
    Hello
    I add the https access and the route of gateway :
    https-server vrf default
    ip route 0.0.0.0/0 172.28.100.1
    But the gateway not ping. The switch 6100 is level 2 and the connect to other switch is HPE 2910AL (level 3 ?) it's a problem ?
