Become a Member
I want to implement L3 mobility between 2 cluster iap 93
can you give me the configuration ?
As an attachment there is a diagram of my installation and configuration page
Download a copy of the IAP v.4.0 Users Guide. Chapter 16 - Mobility and Client Management cover the configuration in detail.
At a high-level you need to point the VC's in each subnet to the other VC's similar in concept to doing static routing. They should have statically assigned VC IP addresses.
Thank you for your answer.So in the first table I get the IP address of the virtual controller of each cluster (192.168.100.1 and 192.168.200.1).But in the second, I do not understand what to enter ??
For the second box you list the subnet of VC 1 and the subnet of VC 2.
Here is a tutorial I put together a while ago. It is on an older version of SW so the screens may look a little different:
In your example, is it necessary to input the VC IP addresses and subnet settings on all VCs on the "campus", or just set them in the one you want to be the main L3 mobility controller?
