Become a Member
Hi, does anyone know if is it possible to configure NTP in a 2930F switch that is managed by Central?
I cannot find that setting anywhere for switches.
you can do it through the WebUI in Aruba central.
once you are in settings use the system tab and then time
your options are Time Sync Method =SNTP
and if you choose the mode as unicaste then you can add the NTP server
https://help.central.arubanetworks.com/2.5.0/documentation/online_help/content/switches/cfg/conf-time-sync-method.htm?Highlight=time%20sync%20method
