I've only ever accomplished this with custom regulatory domain profiles. Essentially you can select which channel(s) you want allowed and then do an AP-specific or AP-group assignment of that profile. I would recommend AP-group as you could identify which APs go to which channels and just group them. If it's only a few, AP-specific is equally as easy.
Not sure if there's a better way, but this has worked for me in the past testing client compatibility with UNI-II channels.
Good luck!
Michael Haring
Original Message:
Sent: Feb 14, 2024 04:34 PM
Subject: Configure static AP channel, Running 6.5.4.12
We have inherited a older MM running 6.5.4.12. We are in the process of migrating it to 8.10.0.X. To help fix an channel interference issue we would like to set some of the AP radio channels to static channels. ARM is not really doing anything. Can someone point me to the CLI or GUI command to make this change?
