Configure static IP detials on RAP5 ?
  • 1.  Configure static IP detials on RAP5 ?
    Posted Nov 07, 2012 09:10 AM
    I'm looking to deploy a RAP5 to a small office but we are only able to obtain fixed IP addresses from the building owner providing the Internet connectivity.   I've only ever provisioned a RAP5 when it's obtainied it's IP details via DHCP.
    Is it possible to statically configure the IP detials on the RAP so that it can get to the Internet to build it's tunnel
    Note that I need to use the RAP in the traditional method, not in Instant mode.
    thanks
    Lee
  • 2.  RE: Configure static IP detials on RAP5 ?
    Posted Nov 07, 2012 09:16 AM
    Yes.
    You need to make sure that the "Zero Touch Provisioning" image is 5.x or above.  You should see a "Static IP" tab:  http://community.arubanetworks.com/aruba/attachments/aruba/88/241/4/Figure1.jpg
  • 3.  RE: Configure static IP detials on RAP5 ?
    Posted Nov 07, 2012 11:16 AM
    Excellent !
    Thanks very much
    Lee
