  • 1.  Configure uplink from Aruba Mesh AP to switch
    Posted Jul 15, 2022 10:37 AM
    Hi All,
    I have configured 2 Aruba 387 in a mesh cluster, i would like to create a point to point connection between two building where one of them isn`t connected to the company network, i would like to connect it to the network by these Aruba 387 Mesh cluster.
    The cluster seems up and running the way it should including one mesh portal and one point.
    I can ping the remote ap that isn`t connected to the company network, although I can get any data out of the switch that is connected to the remote ap.
    I have Untagged the vlan 500 that is untagged on both sides of the ap and tagged all the other networks that i need on the remote switch.
    Can you guys help me get the other vlans on the remote switch up and running, I think there is a mis config on the uplink from the remote ap to the switch.
    Please see the config bellow:
    And thanks for your attention and help.
    config bellow:
    version 8.6.0.0-8.6.0
    virtual-controller-country US
    virtual-controller-key **Hidden for security reasons**
    name PPUS0201
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap **Hidden for security reasons**
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 9
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode default-access
    channel-quality-aware-arm-disable
    client-aware
    scanning
    rf dot11g-radio-profile
    max-distance 0
    max-tx-power 9
    min-tx-power 6
    disable-arm-wids-functions off
    free-channel-index 40
    rf dot11a-radio-profile
    max-distance 0
    max-tx-power 18
    min-tx-power 12
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    hash-mgmt-password
    hash-mgmt-user admin password hash **Hidden for security reasons**
    wlan access-rule default_wired_port_profile
    index 0
    rule any any match any any any permit
    wlan access-rule wired-SetMeUp
    index 1
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule "Point to Point connection"
    index 2
    wlan ssid-profile "Point to Point connection"
    enable
    index 0
    type employee
    essid "Point to Point connection"
    wpa-passphrase **Hiden for security reasons**
    opmode wpa2-psk-aes
    max-authentication-failures 0
    rf-band all
    captive-portal disable
    dtim-period 1
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-SetMeUp
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-SetMeUp
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 500
    trusted
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    poe
    type employee
    auth-server InternalServer
    no dot1x
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    enet3-port-profile default_wired_port_profile
    enet4-port-profile default_wired_port_profile
    uplink
    no preemption
    enforce ethernet
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
    cluster-security
    allow-low-assurance-devices
  • 2.  RE: Configure uplink from Aruba Mesh AP to switch
    Posted Jul 15, 2022 11:48 AM
    I think u better read here:
    ( Its a bit old ,but do read it all it will give u a clue on what and how )
    https://www.flomain.de/2018/08/aruba-instantap-mesh-iap-mesh/
    (*) If i helped you , Please do kudos me as a thank you (*)
    Aruba AirHeads - Because mobility matters.
  • 3.  RE: Configure uplink from Aruba Mesh AP to switch
    Posted Jul 15, 2022 11:50 AM
    Watch this video:
    https://youtu.be/s_TWWFx2JH4
    And I've attached some PDF guide i found on google that might assist u figure it out.
    Attachment(s)
  • 4.  RE: Configure uplink from Aruba Mesh AP to switch
    Posted Jul 18, 2022 06:20 AM
    Edited by larshaveman@live.nl Jul 18, 2022 06:59 AM
    Hi  Kdisc98,
    I have followed every step from that youtube clip except for the admin status up, because that gives an error this type 387 aruba ap, see the comments bellow different users have the same error when they put this one up.
    But it still isn`t working..
    all help is much much appreciated.
