Your drawing is from the labguide and not from your topology. You have a connection between SwitchB and SwitchC in your topolgy. The Lab guide have a connection between SwitchB and SwitchD.
Perhapos you have used configuration for SwitchC in device SwitchD, or your connections are between wron devices.
Arne Opdal
Original Message:
Sent: Jan 08, 2024 08:15 AM
Subject: Configuring OSPF on Aruba CX switches
Thanks for getting back to my email...this is the diagram...I followed all the commands...this is the beginning of the document...I brought all my ports up as indicated...then I enter show lldp neighbor and the information below appears.
Original Message:
Sent: Jan 05, 2024 05:00 PM
Hi there,
Can you give me an outline or a diagram of how your switches are connected ?? so that I can help you better. From your Virtual switch I can see that A&C are neighbors for switch B and hence it is showing those rather than the one in document which I assume might be connected in a different fashion.
Original Message:
Sent: Jan 05, 2024 01:50 PM
Need a little bit of assistance...working on this lab called Configuring OSPF on Aruba CX switches. I started the lab and entered the following information below based on documentation. I enabled port 1/1/1-1/1/3 no shutdown on Switch A, B, C, D. Then it says to go to switch B and enter the command show lldp neighbor-info. When I enter this information on the virtual switch, it doesn't match what the documentation says. Could something be wrong with the lab? I tried moving more into the lab but feels like something is missing. Any suggestions? Dont want to get too confused. Plan on taking my ACSA in February.
Documentation:
Virtual Switch
