Comware
  • 1.  Configuring Radius on H3C-S3600
    Posted Sep 30, 2019 05:50 AM
    I'm trying to configure radius for H3C-S3600 using shared key but I have Error: Failed to set password string :
    primary authentication x.x.x.x key cipher xxxxx
    the key'length is 26.
    Thank you.
  • 2.  RE: Configuring Radius on H3C-S3600
    Posted Nov 26, 2019 01:53 AM
    Hello
    try it without the" cipher" like below:
    primary authentication x.x.x.x key xxxxxxx
    if that doesnt work try the same above command with a smaller key, i would suggest starting with an 8 character sheared secret key for testing purposes
